33x12,5x17" tires, what offset?
  • 33x12,5x17" tires, what offset?
    Howdy!
    I have 2001 prado LWB, with 1 1/2" (38mm) body lift kit and OME +40mm suspension kit.
    I would like to fit 33" tires, but im not sure of the offset for the rims?
    Tried to search the forum for the info but didn't find find it.
    Anyone here has this combination?
    315/75R16 is the closest I could find in this forum which match your width but is 1.6" bigger in diameter. Unfortunately no mention of offset in his post.
    http://www.pradopoint.com/showthread...674#post314674
      To get tyres aligned with the plastic guards the following works quite nicely:
      285's = 0 offset
      255's = -13 offset
      Note that these may rub on guards so some trimming may be required. If you wish to keep trimming to a minimum, for the 255's go for 0 offset or even the original +15.
