Minimum Vehicle Preperation Requirements
This topic is closed.
  • #31
    Re: Minimum Vehicle Preperation Requirements
    Top work Stuart, does this also include the non winch deluxe bar from ARB with the bash plate?
    Regards,
    Big Fella
    2007 Prado GXL D-4D Auto. Black. Cooper ATR's, ARB Bull Bar, Safari Snorkel, ARB Dual Battery, Sandgrabba Mats, Black Duck Seat Covers, Plastic Bits on the front, Mesh Grill Guard, Tinted Front Windows, Towbar, Reverse Sensors, Lightforce Blitz 240's, ORS Drawer System. ScanguageII, Stebel Truck Horn, Icom 440 UHF Radio and BIlstein/Ridepro Premium Lift Kit.
    If you can't fix it with a hammer...... you have an electrical problem.
    [img]http://img.photobucket.com/albums/v655/pradovx96/Web%20photos/emailsig.jpg[/img]
    • #32
      Originally posted by PradoGXL08
      I have spoken to ARB Head Office here in Bayswater, and I have been advised for those who have an ARB Deluxe Winch Bar (suit 2007, 2008,2009 model 120 series), which included the Front Bash Plate, that the "Eyelets" located 90 Degrees Vertical to the Toyota Tie Down points, are Recovery Points..
      ARB are in Kilsyth and they may be recovery points but they won't be snatch points.
      • #33
        I spoke to my local ARB store today as my winch bar is getting fitted as we speak. They said they have been trying to get an answer out of head office on the state of the OEM Tie down Points and still dont have an answer. The 120 Bar had recovery points built into them, however ARB didn't incorporate these into the 150 bars. If ARB has an answer when I pick up the car this afternoon ill let you know.
        • #34
          All good points..
          I have a TJM delux winch bar (alloy) and they way it is mounted it takes away your option to mount the rated recovery points to the chasis(swing the radiator mod). The mounting bracket completely bolts over the area where the recovery points would be fitted.
          I have seen another setup on prado point where another person mounted two rated tow hooks to the underside of his bull bar.
          Any comments?
          Regards
          Wilko
          • #35
            Hi
            I had my bar fitted today to our 150 and there aren't any tabs, loops or holes for recovery. The bar and bash plates go around the original Toyota "tow hooks" the ARB guy said that the known manufacturers don't have "rated recovery points" yet. He did mention that the original points were very solid and with a equalising strap should do the job. The concern is not winch recoveries or towing, rather savage use of snatch straps, nothing new there though.
            Regards, Richo.
            • #36
              Photo's????
              [b]Rob[/b]
              • #37
                Here are the photos of the bar, bash plates and the tow point.
                Under the ARB sticker is the left tow point.
                You can see the bash plates front and side around the tow point.
                • #38
                  Hi Richo,
                  What model 150 is it?
                  Stuart
                  Stuart Trevena
                  [COLOR="#FF0000"][B]2008 Prado GXL D4D 3.0L T/D 5 Speed Auto Colour: Dune with loads of Extras[/B][/COLOR][COLOR="#0000CD"] [B]and 2015 Tvan MK4 Murranji Offroad Camper[/B][/COLOR]
                  • #39
                    Hi Richo,
                    Stuart
                    Hi Stuart
                    It's a GXL V6 auto.
                    Regards, Richard.
                    • #40
                      Lookin' good Richo. I also like the look of the ATZ. We'll need another photo shoot now .
                      LFaR.
                      • #41
                        Hi All,
                        I did speak to ARB a few days ago regarding the issue of Recovery points and the ARB Deluxe bar.
                        They have advised me today that my request has gone to the National Manager for a written reply.
                        As soon as I get this, I will post his repsonse.
                        Stuart
                        Stuart Trevena
                        • #42
                          Hi All,
                          Stuart
                          Hi Stuart
                          May I propose that the fact that points aren't on the new bars for the 150 that the answer will be "tow points" not recovery points. The other point to consider is that if the bar is fitted with air bags then the crumple mounts would preclude snatch recoveries.
                          Regards, Richo.
                          • #43
                            Hi Richo,
                            This is why I have taken this step - to get a clear answer from them.
                            There have been too many members guessing, like you.
                            If I need to modify (drill large holes and angle grind others eg bash plate) my Prado to fit an aftermarket recovery point, then I will withdraw from the GTG.
                            My vehicle is being setup as a ULR (Ultra Long Range) tourer. That is why I have fitted a 160L main Tank.
                            Not for Hard 4wd trips, like Watagans/West Wallsend trip on the GTG.
                            We all need to know for our own benefit.
                            Stuart
                            Stuart Trevena
                            • #44
                              I don't believe this to be correct however have a go at an explanation anyway
                              • #45
                                Would having a winch be a suitable substitute for a front recovery point.
                                When picking up the car from ARB after getting the bar fitted, I was speaking to ARB about front recovery points, and the comment they made was "You dont need them now you have a winch, instead of getting someone to snatch you out if your bogged/stuck, just use the winch instead, thats what it is designed for.
                                With this in mind, they seem to believe that the need for a front recovery point for snatching is redundant. Thoughts?
