120 GXL vs VX vs GRANDE
  • 120 GXL vs VX vs GRANDE
    Can someone tell me the main differences between the spec levels.
    Mainly looking at a 2003 or 2004 V6
    '97 Prado RV 2.7 LPG, 2"OME lift TJM bullbar, airtec snorkle, 72 lt aux fuel tank. Wishing for better front seats!
    http://www.toyota120.com/GenDocs/2005AusPradoBro.pdf
      I can't list the full intricate difference without consulting the brochure from that era but what I can advise is this.
      If you can afford it, go for the VX from late 04. This is because the 5 speed was introduced in late 04 and the VX has traction control. The reason this is good is because there is slightly less fuel consumption with the 5 speed and you can plug in a scan gauge for vehicle diagnostics. The traction control also allows you to drive in low range without locking the centre diff. This is useful for reversing a trailer up a hill on a concrete driveway without causing transmission wind-up.
      So now for the differences.
      The VX has these over the GXL:
      Rear air-cond
      Traction control, Hill descent control, Electronic Stability Control
      Climate control
      6 airbags
      Electric driver's seat
      6 CD stereo
      Roof rails
      The Grande has these over the VX:
      Sunroof
      Self levelling rear airbag suspension
      TEMS shocks
      Leather seats
      Satnav
      With the traction control, certain models may be optioned up with Option Pack 1 or 2 which adds more airbags and traction control. The way to tell is that the transfer case lever has the letters L, N, H on it and there is a separate centre diff lock button. This button allows you to engage low range without locking the centre diff.
      amts
      Ninja Poster.
        Thanks for that.
        It looks like a VX is worth it for the extra's.
        How reliable is the Grande rear air suspension and can it be lifted?
          Originally posted by Kalex View Post
          Thanks for that.
          A few of us Grande owners have had issue with the rubber deteriorating. Yes it can be lifted quite easily. The front suspension is still the same as the other model Prados. The rear (given the age you are looking at) would need aftermarket airbags from the Airbagman pretty soon.
            Im pretty happy that you put this post up as I am also in the market and not sure which one to pick haha
            Josh0887
              5 speed auto/6 speed manual was introduced to the V6 in Sept 2004.
                Hi,
                Can someone please tell me the main differences between the GX & GXL models for the 2007-2099 diesel?
                Ty
                  Surfie I have the last of the 120s brochure in pdf, pm me an email address and I will pass it on though it doesn't cover the 2099 model with the hydrogen fusion drive.
                    Thanks mjrandom, did that.
                    Oops 2099, obviously meant 2009
