Buying 99 RV 90 series 3400
  • Buying 99 RV 90 series 3400
    As title says, my mate is looking at a 99 RV, Question I have is there doesn't seem to be a CDL switch. Its not there at all. I know silly question but it should have it even in an RV model shouldn't it otherwise cant lock it in. CDL goes in automatically when low range is engaged but high range???. Any idea why wouldn't be there? Any help appreciated.
    Steve
    2000 Grande
    Toyota Alloy Bar, IPF 900XS, 50 mm Lovell Springs in rear, Safari Snorkel, Kaiser Roofrack, Milford Cargo Barrier, Hercules AT's, Blue tongue compressor, Uniden UHF, Dual Batteries, Home made rear drawers, 45l Waeco with Waeco temp monitor, Side & rear awnings
    its a full time 4wd. the centre diff locks when 4wd high or low is selected.
      Hi Steevo
      The Grande has the switch for CDL. The RV, GXL, some VX use the stubby stick to lock CDL. Should have a orange light come on the dash when CDL is selected. Hope this help's
      96 3.4 GXL, 2" lift, Poly airs in rear, 32" BFG muddies, Lightforce 170's HID's, TJM rack, Awning, Twine on board shower, GME uhf, Dual batteries & monitor, Storage system, ARB fridge, LED rear lighting, Safari snorkel, Brown Davis bash plate, Ironman winch bar, Runva 11xp winch, Roadsafe recovery points, ARB compressor, Tyre dog monitor, AJ's sliders, Hema hn6. The to do list is getting shorter.
        Originally posted by Playdoh96 View Post
        Hi Steevo
        This is only true with the updated model, all grades before the update use the lever.
          Thanks guys so how do you get high CDL'ed? I know when low range is selected it automatically locks CDL but how does it work in high range? I feel stupid asking as my 96 RV 2.7 prado I had years ago had a button to push like 80 and 100series. I just cant figure how you engage the CDL without a switch to activate it?
          Steve
          2000 Grande
            Normal usage on road the stubby stick should be pull all the way down. This has CD unlocked. Push stick forward 1 notch and the is HI 4 CD locked. Next notch forward is transfer box is in neutral. And all the way forward is LOW 4 CD locked. Hope that helps
              Thanks Playdoh I will let my mate know Cheers mate
              Steve
              2000 Grande
