Hi all,
I have a swing-door garage that opens to 1870mm. I've adjusted it as far as I can, and even taken to it with an angle grinder to remove the handles - the only way I can increase the opening further would be re-roofing, and I don't want to go there
I'm looking at older models (e.g. 2005-2008ish). Specs suggest GXs are 1850mm, GXLs are 1865mm. I'd prefer the GXL, but 5mm just isn't enough clearance.
I'm wondering whether those numbers would be significantly lower by the time you add the weight of a bullbar, towbar, extra battery etc?
Any creative suggestions for shaving a few cm off would be appreciated e.g. smaller tyres?
Thanks!
Thanks!
