Hi All,
Really love this website. Keep up the good work moderators.
I currently have an 80S LC Oiler and would like to come out of the dark ages and catch up with the traffic, prevent any further hearing loss, and improve some safety. Best way for this is a Prado, I thought, so I took one for a run from Yota shop and loved it...really loved it, not hard I hear you say look what you are in now. Agreed. BUT, after scouring the contents this fabulous web site I have become a little despondent and need some reassurance.
From this website it appears Prado have some inherent flaws (?) and I need someone to put this in context. The below was sourced from hours viewing this website.
-Rear Diff Failures is this common? How much to fix?
-Rear door cracks- Common? Can it be fixed so as not to re occur?
-Inner Guard cracking? as above?
-In the Petrol form it seem the idler bearing for the drive belt fails regularly and is approx $500? to fix if Toyota does it.
- Rear driveshaft clunk, I think from the slip splines on the drive shaft but I suspect this is tolerable.
Are there any I have missed? And am I being unfairly bias?
Not saying the 80S is perfect, but it has got me to 240K with little fuss, front end was fixed but for $700 in parts, (labour by self) for CVs,bearings,seals,discs,pads etc and $500 for a radiator. It is 15yr old and it happens.
To add some balance the Patrols are not with out issues too, you do not have to scratch to deep to find a 3L diesel Engine failure (definately off the list), don't own an oil well so not a Petrol one. The Paj has some DPF (Deisel Particulate filter) problems, can't seem to find other problems but is starting to get a bit small.
So when selecting a new 4WD is it a matter of lesser of all the evils, and the above list of the failures are from those using them in extreme circumstances, or is it a fair comment to expect these to happen?
Looking at the auctions where I bought the 80S from 10yr ago and they seem to be $34K for an early 05 late 04 GXL auto petrol with 80K to 38K for a VX of same.
Matt
Matt
