Cheap Waeco 50-65L Fridge Slide from 4WD SupaCentre
  • Cheap Waeco 50-65L Fridge Slide from 4WD SupaCentre
    This is a pretty good price for the Waeco 50-65L fridge slide, only $256.30 incl delivery.
    http://www.4wdsupacentre.com.au/prod...de-50-65l.html
    Deal ends midnight Mon 7th Jul 2014. They also have 30% off assorted accessories ending the same time.
    Great pick up Corine. I will have a look, should accommodate a 60L ARB by the looks. Need one for the C-ute....
      It's a bit less than what I paid for mine on eBay a while back ($297), at the time that was a good price too. I'm very happy with mine, the only niggle is the locking pin has too much flex in it so when the slide isn't weighed down with a fridge it tends to rattle a bit. If you need dimensions let me know, I'll run outside with the tape measure for you.
        I can't get there today but I will take the C-ute replete with fridge over tomorrow so no need but thanks for the offer. I was going to make my own but for that price I won't bother. I take it you can bolt down the base pretty much anywhere there is metal? I fitted some rivnuts to hold the fridge down so it would be nice to use these for the slide. Ta
          I have the slide bolted to a false floor made of marine ply. Well actually at the moment it's screwed down but plan to replace those with tee nuts when I find some in metric sizing. There's a bunch of mounting holes drilled through the metal frame that can be used for mounting, M6 or M8 bolts should fit.
          Dimensions are on the listing too, didn't read it properly LOL.
          Have added a pic of the slide opened out. If you look closely you can see the holes in the side frames, there's also 1 or 2 in the end pieces as well.
            Thanks for that, #2 found out it is 60mm too short. Anyway I think I can make it work nonetheless. Off to have a look tomorrow.
              Ok, went today to look at the slide and I must confess having dealt with TJM and ARB these guys were an eye opener for all the wrong reasons. No stock, no demo, no interest and pretty much no idea. Maybe available in two or four weeks time, only one in stock in the country. Could be already sold though and so on. No thanks. I will keep my money. Plenty of options including building myself as I was originally planning. Ah well thanks Corine for the link.
                Mine came from Seabreeze Industries via eBay, great service but then I didn't have to trial fit as I have a Waeco fridge which matches the slide. I have dealt with 4WD SupaCentre in Lilydale Vic in the past and they were great.
                  Lots of options on evilbay so I will probably go that way. Pity really but I won't be going back yo that particular place.
                    Fido, I have an additional pin on mine that locks it in place (came with it). I only use it when the fridge isnt on it other wise yes mine gets a rattle as well and also you would have to take it out every time you wanted to release the latch to slide the fridge out, but it certainly stops it rattling. I got mine off ebay for $100. Had a bit of sand in the rollers but took it to work and got the maintenance guys to clean it all out, regrease etc and slides smooth as....Cheers Steve
                      Yes Steve, I have the locking pin that fits in the LHS runner up the front. I just find it has too much play and still lets the slide move a little bit hence the rattle.
