Originally posted by t303
View Post
PradoPoint Upgrade
I did a quick google search to find the answer. Did the trick just fine.
Cheers[COLOR="black"][b]William[/b][/COLOR]
Originally posted by amts View PostI encountered 2 questions
1. What is the spanish translation to Prado (or something like that)
2. What is the size of the GXL wheel in inches (or something like that)
2. 17
A bit of humour I guess to prevent bots.[B][SIZE=4]ntp
I thought it appropriate (and a little humorous) and yes it is to prevent bots and time wasting spammers. If you are keen to join up then great. I didn't think a minute of Googling would be an issue.
The only reason I know about the Spanish meaning is that on checking Toyota's trademark there is a note about it:
Endorsements: The applicant has advised that the translation of the SPANISH word PRADO appearing in the trade mark is LAWN or MEADOW.
G'day Folks,
I jumped on this morning and noticed the new site.
I only had the the 1 tricky question in order to reset the password.
I found the Question relating to the meaning of Prado in Spanish a little confusing, but I worked it out in a couple of mins.
A quick Google translate came back with 4 possible meanings.
From the dictionary is a noun for:-1. meadow
2. field
3. green
4. lea
I must have been lucky to use Meadow as the answer.
All I'm waiting on now is direction for setting up Avatar pics.
Will come in time I guess?
CheersStewy
Originally posted by don1 View PostIts a bit of fiddling around to get use to. But anyhow happy with the update. Whats with the member, junior member & senior member?
Having said that, I'm loving the new forum. Over time it'll be customized and be even better.Cheers, Leon
Optix Photographix
Hi Aron,
Good job well done :-)07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Originally posted by t303 View PostI have just wasted an hour trying to login to change password and your questions are so vague as to be useless. Both questions have no definitive answer. On asking advice over on LCOOL it appears I am not the only one having trouble. The translation was any of a possible four or more answers (none worked by the way), and not specifying the year of the Prado means there are at least two possible answers. I could not even contact you for advice because I was unable to answer the very same security questions!
cheers
The update forum looks the goods though...good job Aaron.
