Prad VX 150 Series - Securing a car fridge
  • Prad VX 150 Series - Securing a car fridge
    I have a new PRADO VX 150 Series and a WAECO car fridge. I need to secure the car fridge in the rear luggage compartment but ARB say there are no securing points and there should be a Toyota accessory that locks into the channels on the floor. Toyota say they do not have such an accessory and noone else has been able to help. Has anyone had the same problem and found a solution?
    Jimber
    Don't know of an actual Toyota accessory , but aren't there tie down or anchor points in the back,
    in which a proper fridge slide could be fixed or mounted?
    Relentless Reckless Forever .
      Search for Luggage Hooks and you'll find the answer to your problem. A mob in the US Called Pelican Parts have the perfect solution for you.
      VXWesty
      [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
      [/SIZE]
        I have a GXL with no easy provision to secure my fridge slide or other luggage. My solution was to use some 12 mm ply coverd in marine carpet to match, cut out to the exact size/shape of the luggage area. Then I bolted my slide to it and added various other tie down points for other bulky luggage. The shape means that side to side and for and aft movement is not possible and I just use some heavy cable ties to fix the back to the head rest posts on the folded down seats. You could even use the very lightweight tie down points to further secure the false floor if you wished but mine seems very secure when doing most offroad work.
          VXWesty
          Thanks this turned out to be very useful. I am pursuing Toyota re the so-called deck hooks which fit into the deck rails in the VX and Kakadu. Back in 2009 the story was that these were only available in Europe but I am hoping that has changed.
            Does anyone have a link for these?
            Tried every combination searching but can't bring it up!
            Matthew
            2011 GX TJM type 13, Airtec snorkel, TJM bash plates, Gensis HID lights & a few antenna's
              This link will take you there
              http://www.pelicanparts.com/cgi-bin/...curing%20Rings
              Mine arrived yesterday, 10 days delivery time and pretty schmicko plus lots cheaper than Toyota ($88 ea)
                Fantasic - got that web site before but couldnt nail which ones
                Thanks Matthew
                  Just a question
                  Originally posted by bundyman View Post
                  i have a gxl with no easy provision to secure my fridge slide or other luggage. My solution was to use some 12 mm ply coverd in marine carpet to match, cut out to the exact size/shape of the luggage area. Then i bolted my slide to it and added various other tie down points for other bulky luggage. The shape means that side to side and for and aft movement is not possible and i just use some heavy cable ties to fix the back to the head rest posts on the folded down seats. You could even use the very lightweight tie down points to further secure the false floor if you wished but mine seems very secure when doing most offroad work.
                  do you have any pictures of this bundyman
                  [url=http://postimage.org/image/1vynucrno/][img]http://s3.postimage.org/1vynucrno/2011_prado_side.jpg[/img][/url]
                    Here you go Stumped.. finally a pic.
                    I haven't fixed it to the floor at all. Only because I could really figure a easy way to do it. Near the seats I have just used a heavy cable tie to fix it to the headrest posts of the folded down rear seats, both sides.
                    With a load on and tied down it has never moved!
                      Can anyone let me know how they have secured their waceo without having to buy or use the fridge slide. It looks like I can only anchor it at 1 end
