Drag Chains
  • Drag Chains
    You'll have to excuse my ignorance on this one but what are drag chains used for in vehicle recovery? I've never seen them used, demonstrated or even discussed.
    Drag chain is used to drag fallen trees off the road or to drag logs to use as fire wood.
    Chain could be used for towing in an emergency.
    Winston.
      Drag chains as their name suggests, you can use drag chains to pull things along the ground.
      Track clearing of fallen trees or rocks or Nissans.
      Also anchoring the winch vehicle to an immovable object when winching out another stuck vehicle.
        Bloody Nissans always littering the tracks.
          Also if you are using a High Lift Jack as a winch, drag chain can be used in hooking that up as well.
            Thanks Guys. Apreciate the feedback.
