Where do you secure your winch hook?
  • Where do you secure your winch hook?
    Where abouts do you store your winch hook on a aftermarket bar with synthetic rope? I have a Tigerz11 12000lb in an ARB winch bar and have tried two options:
    1) Have about 18" of rope exposed and have it hooked to the recovery point, but there are several edges of the bar touching the rope that could cause issues over time.
    2) hooked to the high lift entry point which eliminates any of the rubbing issues but concerns me that it's not actually hooked to anything. It's only the tension holding it in place.
    I know I could get a sleeve to protect the exposed rope but even then I thing the tension on the rope against the bar edges could cause some damage.
    What do you do?
    [SIZE="2"][COLOR="red"]2010 Prado 150 GXL TD[/COLOR] - Previously Darren253
    My Rig Build: [url]http://www.pradopoint.com/showthread.php?17046-Darren-s-GXL-TD-150[/url][/SIZE]
    I have the same winch with synthetic rope in sovereign bar andni have it fully spooled in where the hook sits sideways against the hawse fairlead.
    Frank
    Silver GXL 4.0 V6. Rhino 3 bar HD racks and Rhino Platform rack. Open Sky Side and rear awnings. ORS Rear drawer and fridge slide. Waeco 50 L Fridge. Smart Start Solenoid dual Batt Sys. Century 100 Ah deep Cyc Batt. ARB Twin Lockers. Tigerz 11 120000 Lb winch. 2 inch Lovells Springs and Bilsteins Shocks. Poly Airs in rear. Outback Water Tank. Happy with what i have and where it will go.
      mate the winch sometimes comes with a strap to connect the hook to the fairlead. failing that, i'd look at getting a strap.
      louie
      gxllouie
      Silver 150 GXL V6 Auto: TJM T13 bull bar, Avenger Mako TDS 9.5 winch, 2" lift - Bilstein shocks King springs, factory tow bar, Piranha battery tray, Red Arc isolator, E-Nex DC24MF battery, GME TX3540 UHF, ARB 47L fridge, ARB fridge slide, IPF spotties, Tekonsha P3 brake controller
        You've seen ours Darren.. It goes onto the recovery point. Don't really have many options with the billet fairlead as there is no recess.
        Mitch
        P.S. You didn't muck around fitting that up did you!! LOL
          Nope... Fitted that evening! all be it upside down so i had to wait until i got back from Queensland to refit it and rotate the gearbox again. He's a photo of what i'm on about!
          Darren253*
            I wouldn't be worried about it being held in via tension only. That should be plenty good enough
              updated photos...
                Hmm, that doesn't the best after all...
                You don't have aftermarket recovery points do you Darren?
                  No... I'm still waiting for Outback idea ones with the cutout for the ARB/TJM bar to come into TJM Perth. They've told me it'll be another 3-4 weeks. I normally use an equalizer strap across the two factory points at the moment.
                    Is that when you have to reverse to recover some other vehicle?
                      But of course... Normally a Nissan or Jeep!
                        Legally, the hook must be hard pressed against the fairlead.
                          Well there you go. Learn something new everyday...
                            Apparently it is so the hook doesn't hurt a pedestrian..... Personally, I think the bullbar rapidly approching would be more of a concern for them. But we can never figure out why they make these rules.
                              This is what I meant to say about mine. The hooknis hard up against the fairlead.
                              Thanks for wording it better crooza
                              Frank
