cannot get first or second gear. has anyone else had similar problems with this model. Has done 230,000 kms of trouble free motoring, just replaced the clutch
Keith
If you just replaced the clutch, sounds like a good place to start, maybe the clutch plate wasn't fitted propley, as williade says, can you get first or second gear when the engine is off?
Many thanks for your prompt reply. Just tried it stationary, still having problems seems to be worse when driving trying to engage 1st or 2nd. No noise other gears are fine. Tried with engine off still had problems. Feels like the gear leaver does not go far enough left to engage the low gears. Again thanks for taking the time to reply
If the problem only started after the clutch was replaced, the issue could be with the linkage? The transmission would have been removed to install the new clutch and the shift lever may not have been reinstall correctly.
