Hello,
Currently installing my Avenger / Kingone TDS 9.5 winch. A wire diagram wasn't supplied and there isn't one on the Avenger and Kingone websites.
On the winch it has three terminal posts to bolt the cables to. They are:
A: (white cable)
F-1 (yellow cable)
F-2 (blue cable)
The three cables for the control box are colour coded - Blue, yellow and white which helps when connecting them to the control box but not to the winch. Does anyone know how? (I have worked the cables out but also got a copy of a wire diagram from Avenger 4x4)
The long black cable (earth) bolts to the winch casing on the opposite side of A: and the other end to the negative terminal on the battery
The long red cable bolts to the terminal post colour coded red on the control box and the other on to the positive terminal on the battery
Last, what battery do yuo use for the wireless remote? Its not AA or AAA. It needs to be about 3cms long and about the same thickness as a AAA. Battery is a L1028 (12v)
Here are some photos
A: (white cable)
F-1 (yellow cable)
F-2 (blue cable)
