Which tow rope?
  • Which tow rope?
    Ok, so I broke my old steel rope tow rope the other week and have been looking for a new one. There only seems to be two on the market, a cheap peice of orange rope with some crap shackles at about twenty dollars and a blue and white bungy cord with a cheap hook on both ends for around the same price. Both look extremely cheap, nasty and dangerous to me.
    None of the 4x4 shops seem to market anything.
    What do you guys use / recommend?
    What are you using it for?
      Go to a rope or lifting tackle business (Bullivants or similar) and have a chat. It's not too expensive to get them to splice loops into each end of a suitably rated piece of dyneema or whatever you choose and then you can use rated shackles.
      Confidence - The feeling before you fully understand the situation
        If you have an old snatch strap laying around you could use it, just don't drag it on the bitumen they wear through rather quick I hear.
        Ron.H.
        2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
          I'm using it for towing??
          A snatch is a bit long for towing a vehicle as it gives the impression there is a gap between the cars and another may try and pull in. Getting one made seems to be the go I think.
            try your local bcf. i seen some in there just yesterday in syd
            [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
            ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
              Snatch strap will have too much 'spring' grab your winch extension strap and if its too long double it over.
              Matthew
              2011 GX TJM type 13, Airtec snorkel, TJM bash plates, Gensis HID lights & a few antenna's
                I was faced with this same dilemma last week. Clutch died in the Rodeo and I needed to get the thing home. Choice of towing or driving home clutchless. Unfortunately the old length of sisal rope (about 50mm diameter) that I used to use had died towing one too many tractor out of a bog. Snatch straps are really not an option and the commercial ropes on sale at servos were not doing it for me. Sadly there were not nice noises coming from the bellhousing when the engine was running so I took the third option and got a mate to tow it home on his car trailer. Let's know what the poly rope costs if you go that way.
                  I have found a length of about 6mm steel cable which I could get spliced up but steel cable tends to be very harsh on vehicles when taking off, cornering etc due to the lack of give. Does anyone know of a good rope that has a little bit of give in it that would be suitable for the purpose? I might visit a yacht shop and see what they have. Some springer line might be ideal.
