a piece of paper might not be enough. i would hold a thick rag over it tightly with my hand and see if it stalls.
Snorkel Testing!!
would that damage the car? starving it from air causing it to shut off?2012 Suzuki jimny 50mm lift, 215/75/15 hankook muddies, 30 inch dual row light bar, gme UHF, arb compressor, rola roof rack, ironman awning, projecta dual battery system with yellow top optima, evakool fridge freezer and arb air locker this month!
Thanks Beast :-)2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
When I bought my Safari Snorkel from ARB in Brisbane I was told that there is no warranty if it wasn't installed by them (If I were more critical at the time I would have enquired re what amazing warranty WAS offered by them if they did the install).
Did the install myself and sealed all of the joints with silicon, but did not seal the water drain hole duck beak thing in the bottom of the air filter box. I have since noticed what looks like evidence of moisture making its way to the air filter box, not surprising if driving through pouring rain at 100km/h regardless of the drain holes on the snorkel head. Have those who completely sealed every drain hole noticed any moisture in there from rain?
When I had my Prado in getting some items at ARB. One of the guys had a look at my safari snorkle and noticed that it wasnt fully sealed. He promptly sealed it up, no charge when he was doing a once over.Originally posted by letsgoplaces View PostFrom a post i have read, ARB don't take responsibility for the fit up being airtight especially from the guard to the filter. That could be just one bad experience or ARB's way.[B]Robert
Yep there is a waterline a couple of mm around the sealed duckbill valve. Those couple of ml water are unlikely to make it through the filter to the engine. A 100 ml or so leaking in when you stall in a deep water crossing could do real damage. Just my opinion.Originally posted by 2002TX View PostHave those who completely sealed every drain hole noticed any moisture in there from rain?Greg - 08 D4D Prado,
I've had a gripe about this a few times on here. The Safari snorkel i fitted to my 95 T/D was really good. The pipework supplied to connect to the airbox was absolute rubbish. The expect you to connect a generic rubber pipe to your existing ducting. The existing ducting is nowhere near waterproof.
I ripped all the existing ducting out and made up a new pipe with exhaust tubing, connected it all with rubber pipe and clamps. Only way to be confident in a decent water crossing.
Chriso[COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
Yeah Chriso, as per my previous post I totally agree with you. The pipe work from safari to connect the flexi pipe from the snorkel to the original inlet was a total joke. That many bloody bends and joins was stupid, and I swear my performance died in the arse after the snorkel was fitted, was gutless prior, snorkel made it worse. I totally sealed my'n off 100% myself, even the ducks beak was sealed up, pop rivets holding the plastic shit together from the factory had a blob whacked over them as well inside the air cannister. Never had an issue with excess water in the air cannister after driving in pissing down rain.......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Hey Guys,
So your saying its best to seal up that little ducks beak thingy in the bottom of the air box? Curiously what is the best way to do it? What is best used to seal the rest of the pipes together?
Thanks Troy2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
Yeah Troy, I filled my'n with sensor safe silastic (black). I pulled the duck beak out and sealed around it then put back in, then I filled it up as well till it was coming out the top and bottom, then smeared it around. I did it with all the joints as well, filled them up then pushed together tilll it spewed out then wiped around join as well then wiped off excess. I didnt drive myn for 12 hours after doing it so none of the seals would vibrate and seperate. This was on the 90. Going by the 120 safari I have (but havnt installed it yet) there is only 2 small rubber sleeves so will only be a wipe over as such. I also did where the rubber induction pipe joins the throttle body, just a small smear then push the rubber felxi pipe back over. Also check any of your rubber flexi pipe (original toyota ones) to make sure there is no deteriation or cracks in them. The 90's did seem to crack in between the ridges with age. When your doing a crossing and your going along nice and steady its fine (you nearly get away without having a snorkel, especially with a blind on) BUT it's if you get hung up on some thing when yuour in trouble as the water just comes up in and around the engine etc then bang. Only takes a shot glass of water to kill a diesel engine, filter will only soak up so much. You can see in my pictures prior to snorkel fitment the mud it sucked up.......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Thanks for the replys guys good info
Cheers Troy2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
Hello Everyone,
I have finally got around to start sealing up my air intake system, with safari snorkel. And I have a few questions for those guys out there who have already done this or have advice on what to do. First Photo is of 3 holes in the lowest point of the filter box, should i silicone these holes up or not? I assume if water does it get in though the snorkel these holes would allow for it to drain out of the filter box?
Photo 2 is a random hole in the top/front of the filter box. Should I silicone it?
Photo 3 is the ducks beak thingy, which from what i have read most people silicone up, although in design you would hope to think that it wouldnt draw in water. Whats people thoughts on this one?
Thank you
Yep I'd be sealing up every single little hole you see. On my old prado I even smeared a tad on the bolts holding it down (probably a bit over board) Make sure also all the joints are sealed from the snorkel through to the airbox. I had no silicone anywhere on my 90 series which was done by the so called professionals.....I redid the whole thing.......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
