Peice of Cr@p waeco cf 50
  • Peice of Cr@p waeco cf 50
    I have just go my waeco back 2 weeks ago from having the thermister fixed and now as i head off to the GTG i go to put it in the car and adjust the temp and it will not go down only up. After stuffing around with it for a while it is now to high to for cold goods.
    Does anyone now of any sort of factory reset or something that could return the temp to zero??? Help i need cold Johny's for the trip!!!!
    Hutch
    Addicted PP Member
    [b]Rob[/b]
    Geez, sorry to hear that .
    I hope you get that sorted out quick mate!
      Damn Rob. That sucks
        If it is like mine you can flip the 'emergency' switch which will turn it into a freezer.
        Using The Emergency Switch
        ➤ The emergency override switch (Fig. 5 & 6 4, page 5) is
        located in the connection panel.
        ➤ For normal operation the switch should be in the ‘NORMAL USE’
        position.
        ➤ In the unlikely event of an electronic control failure slide the Switch
        to ‘EMERGENCY OVERRIDE’.
        NOTE: in this position the appliance will run all the time and will
        therefore perform as a freezer only.
        http://www.waeco.com.au/documents/33...ERB_inc_DZ.pdf
        D4D
        Addicted PP Member
          That'll probably get you out of jail Rob. You'll just have to drink faster
            Rob
            I have a 47l ARB you can borrow if you like. PM me
            Trev
            Check out our around Aus adventure on FB at: Cummings and
            Goings
              Originally posted by Trevc View Post
              Rob
              Trev
              Now, that's what I love about this forum Sorry to hear about the Waeco Rob.
                position.
                This is what happened last time when the thermister went in went into limp mode and froz everything within half a day? No really practical, frozen milk on the weeties!
                [b]Rob[/b]
                  Borrow Trevc's.
                  Uhm you waste space on milk????
                  Next thing you will admit to salad Your so metro Hutchy!
                    No salad mlc milk, bacon, eggs, and drinks!!
                    [b]Rob[/b]
                      Rob
                      Trev
                      Someone give this man a medal!
                      Seriously - that is a generous offer...
                        What's he gonna do with a medal? At the very least, return the fridge with a 6-pack in it.
                          You can borrow my CF 40, it just needs to be cleaned out after 3 weeks outback first
                            Thanks guys crisis solved, thanks to Trev and Josh for your generous offers but I took the fridge back to the repairer today and 10 minutes later all good. He said something was out of alignment and he was honest in saying that it could have happened last time it was their. No cost so I was happy with that.
                            Hutch
                            Addicted PP Member
                            [b]Rob[/b]
                              Ran this past the boys. Apparently milk is allowed, but the carton should not exceed 600ml. Can I suggest long life milk so it does not need immediate cooling thereby allowing more space for life saving liquids.
