Inverter blowing on a ZR prado.
  • Inverter blowing on a ZR prado.
    After completing 15000 klms with a Waeco plugged in the inverter has blown twice. Does anybody have a solution as to be frank, Toyota have been not so good on advice.
    Run it off 12volt like it was designed to be run?
    2011 150series GXL
      My thoughts exactly, you convert 12V into 240V through the inverter, and then the fridge turns it back into 12V to run the motor. Cut out the middle man and run it on 12v.
        Originally posted by Wandy View Post
        Does anybody have a solution?
        Dear Wandy,
        You don't say what model Waeco frig, but just checking the Technical Specs at the end of the Manual, says that a [CF-50] has a rated current draw of 7.0 amps, at 12 volts [84 watts consumption], and 0.7 amps at 240volts [168 watts consumption]. [Watts = Volts x Amps]
        Now the manual does not explain if this is peak (starting) current, or running current etc, but it is possible that the inbuilt inverter is overloaded [168 watts] either way??* It is clear that it draining much less energy (about half) from the car when using the 12v supply, rather than the rear 240v accessories output.
        There is also a power loss (wastage) in getting converting 12v DC to 240/220v AC, which makes it even less attractive.
        As Andrew says, cut out the middleman, and run it directly from 12v.
        bworth
        * Couldn't find out rated output.
        bworth
        2006 120 Auto D4D, UHF, Toyota Alloy Bullbar, Towbar, 2xDIN Audio/GPS/Bluetooth Unit, Old SuperOscar HID spots, Stock standard body, suspension etc, pimped frig. [I]Wish List: [/I]Dual Battery, Roof Racks, Awning, Drawers.
          buy one of the thumper packs and throw in the back as well or waeco have a portable 12 36amp/h battery you can buy its about 300bucks i think. cheer samo
