Is it 2.5m along the car and 2m out? Or the other way round?
tigerz11 awning
Big Dog
Hi Bigdog, I have one too, yes it is 2.5 m along the car and 2m out.Originally posted by BigDog816 View PostIs it 2.5m along the car and 2m out? Or the other way round?
Mark[B]White D4D GXL auto Mickey Thompson ATZ 4 rib 265/70 R17, Genuine towbar, OME Suspension, ARB Sahara bar, Safari Snorkel, Icom 440N UHF, Rhino sportz bars, redarc BCDC1240 dual battery system, Drifta drawer setup, headlight upgrade.....more to come....[/B]
My Rig Build [url]http://www.pradopoint.com/showthread.php?24451-Mark-s-White-D4D-GXL[/url]
Hi Jimmy, I had the extension made 2.5 x 2.5. I had eyelets put in at 1.9 from the awning side, so if needed it can be a wall with the awning poles holding it down. The extra bit on the end makes either a short wall or a little more extenion.Originally posted by jimmy91 View PostThanks for the reply mate. If you don't mind me asking how are you getting it extended? Length or width?
Worked well at TuffTruck on the weekend, I'll post up a photo shortly.
Sent from my iPad using Tapatalk HDD4D Prado GXL - 2014. 2" OME lift, ARB Deluxe Winch bar, ARB under body protection plates, ARB EZ Deflator, Weaco fridge, Matsen fridge on slide, BFG A/T's, ARB CKMA12 compressor, Oztrail side awning with LED lights PLUS canvas extension, Lightforce XGT's.. Oricom UHF380, GME AE4017
Somytigerz11 awning arrived this week. Bit confused on how you fit it, the were no instructions supplied with the awning. As there are quite few pieces that don't appear on the following link that I found whilst searching the Internet http://www.tigerz11.com.au/2.pdf I'm interested to hear and if possible see a few pictures on how those who have purchased this awning have fitted it to the vehicle I should also note that I have the Tigerz11 clamp on roof rack
I'll attach a photo of the pieces I received in the box once I work out how you attach a photo from an IPad.[SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
[/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
Originally posted by ROY07 View PostHi Fabes have attached a couple of photos of how I attached the awning, I know what you mean about confusing and all the bits and pieces that come with it. I just drilled through the main upright brackets on rack and bolted straight to it.
Hope this helps
Troy[ATTACH=CONFIG]6878[/ATTACH][ATTACH=CONFIG]6879[/ATTACH]
Thanks Troy
I seen a few 4x4's today which have done it the same way also, seems the easiest way.
cheers[SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
