Waeco CF50 Just keeps freezing. Whats wrong?
  • Waeco CF50 Just keeps freezing. Whats wrong?
    Hi all. Got a problem with my Waeco fridge. Its one of the older type that has the line of LEDs as the temp control indicator. No matter what setting I put it on it freezes everything. I set it on 1 yesterday and the thermometer I put in there still shows minus 5 today. Its not running continuously but it is running alot.
    I have checked the emergency switch and that's still off. We have been using it constantly for the last 9 months as a fridge only. It has been off for the last 3 weeks while we were away but when we turned it back on, started to have this problem.
    Any Ideas?
    Travelling Panelbeater
    sounds ike a dodgey thermostat. Will most likely need a fridge man
    Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
      Thermostat, Not that expensive to fix really. I'd say that is what it is mine was doing the same thing and it was a crook thermo.
      Cheers.
      2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
        thermostat shouldn't be to difficult to replace yourself.... Just a matter of getting a similar one with the same temperature ratings.
          It is a common fault of this model, it is actually called the thermister, that puts the fridge into overide mode were it just constantly runs.
          [b]Rob[/b]
            Googled this and got a bit of info including how to check the thermister using a multimeter. Seems its stuffed as it was reading no resistance at all. At least that'll be cheap to fix
            edit: just realized I was supposed to disconnect it before testing the resistance. Oops. Oh well, getting checked out by the waeco fridgie tomorrow anyway.
            Whitey1
              I had the same with mine a few years back and it was red emergency switch playing up (full of dust) when it is in emergency mode it just goes flat out no temp setting. Maybe worth a look??
                It's the thermistor they are a $20.00 plus fitting item and if your Waeco is close to being still in warranty they will probably fix it for parts only at a dealer.
                Richo.
                Sent from Richos iPhone using Tapatalk
