Does anyone else have trouble logging on to your iPad. I am logged on if I use my laptop, but can't log in off my iPad, which is causing a few issues
Problems logging into iPad
Probably because you can't log in to the same user name twice, so make sure you are logged off on your laptop and then try logging in on your iPad.Originally posted by dreamon View PostDoes anyone else have trouble logging on to your iPad. I am logged on if I use my laptop, but can't log in off my iPad, which is causing a few issuesBlue storm 150GXL auto TD with tjm steel bulbar, Xgs gold lift with polyairs, airtec etc..
Try a hard reset of the iPad..[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
Are you using the tapatalk thing?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Hold the square button at the bottom of the iPad and the power button at the top until the screen goes black and then comes back on, displaying the apple logo.. Just let the buttons go and wait until the iPad restarts.[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
Hi Dreamon,
if you mean you can't login to PP from your iPad, I have had a similar experience on occasions where I enter my username and password and click login then get the same view I had before logging in so it appears that I am not logged in. However, when I then click on a something then click back on the Forum link, the navigation bar at the top changes and shows that I have logged in. This only happens on iPad and not everytime.[B]Ian[/B]
A different tangent.. But still iPad related
For anyone using Bigpond and having issues setting up the iPad email to send and receive, I sorted mine this afternoon.
Go into settings and select email accounts. In the POP account info area put in your name, email address and an account description (I find the email address works best). In the incoming mail server, type in the host name, for bigpond it's mail.bigpond.com and then your username, being your full email address. Follow down to the password and type it in.
Click the outgoing service SMTP line next. This will open up a list of servers, select the mail.bigpond.com as the primary server and ensure it's set to ON. Click on the primary server and this will open up the outgoing primary server information. Again, like before ensure the host name is mail.bigpond.com, the username is your FULL email address and finally the password is typed in in the password section.I left the SSL box alone and now everything works great.
I can both receive and send email now on the my iPad. Before I set this all up, I could only receive emails.
I know it's off the thread topic, but might help someone in the future. By the way, this set up works on all iPhones as well to get them to send and receive emails of your handsets.[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
This problem has raised its ugly head again. I'm unsure how it corrected itself the first time but I have tried everything such as a reset and logging off from my laptop but it hasn't fixed the problem. Does anyone have any suggestions how I can log onto my iPad as I don't use my laptop (which I am on now) very often and only take my iPad away. Prado Point is one of my favourite sites so I'm lost without it, any help will be most welcomed
Are you having an issue only with logging onto PP? Or Is Safari not working with other sites as well?Originally posted by dreamon View PostThis problem has raised its ugly head again. I'm unsure how it corrected itself the first time but I have tried everything such as a reset and logging off from my laptop but it hasn't fixed the problem. Does anyone have any suggestions how I can log onto my iPad as I don't use my laptop (which I am on now) very often and only take my iPad away. Prado Point is one of my favourite sites so I'm lost without it, any help will be most welcomedGeoff
Check in Safari settings, you haven't got private browsing turned on, and cookies are set to visited only.Geoff
I had the same issue turned off private browsing and all good.
Hutch- 2012 Prado 150, some TJM Kit.[b]Rob[/b]
