What's this yellow grease under the oil filler cap?
    if it is in a car yard it would have done plenty of short tips from test driving
      Originally posted by Matty & Loz View Post
      I just ended up the butt of another joke didn't i?
      If it were me, I would rephrase that.
        Plenty as in millions to get that sort of result! The engine has had it Andrew.
        Walk away IMO.
          You could always do this to your Grande!!!
          Looks good. Found more piccies http://widebaymotorbodies.com.au/ind...ry=6&Itemid=21
          Pity I've got 4 kids AND the missus.
          amts
          Ninja Poster.
            Run for your life from those vehicles above. Run for your life.
            The Roo.
            Walk away IMO.
            Imagine what the dealer's reaction would be if I literally dropped the filler cap and ran out of there :P
              This will accommodate a few of em!!!
                Now you're talking! Where did you find that one? It hasn't had the chassis extended and the rear suspension is intact.
                I see you've also posted it here before
                http://www.pradopoint.com/showthread...l=1#post332054
                  Very good post searching amts!!!
                  As the post mentioned. I was up in Rockhampton earlier this year and it was in the hotel car park where I was staying.
                  Off topic (sorry) end of transmission......Over
                    ahh catch cans. These things aren't too good for just condensation but more for "blow by" when you crank the boost. If your running a stock motor, stock turbo setup and the standard boost levels, i wouldn't waste my time with one.
                    That yellow grease is water and oil mixed as mentioned. it could be an easy head gasket up to a crack in an oil gallery etc. Full head replacement. Yet imagine all of the oil is now contaminated and its going all the way through the blood stream of the motor. old age will set in like cancer and shes stuffed...
                    Ron - 2004 GX 120 Prado 1KZ-TE manual with a forever changing extras list...
