Replacing essential fluids.
  • Replacing essential fluids.
    Hi all,
    I have a 1996 SWB 90 series running on a 1KZ-TE diesel engine. It was imported from Japan in 2006. It has done 135,000kms.
    I dont have the service / maintenance manual with it and wanted to know what the life of fluids is;
    I use the Caltex Delo Gold multigrade engine oil & Toyota's Type IV transmission oil, but wanted to know when all to change the;
    • Brake Oil
    • 4x4 Transfer case oil
    • Diff oil
    • Power steering fluid
    Sam
    P.S. Does anyone have a pictorial of the maintenance schedule that comes in the owner's manual ?
    [COLOR="#0000CD"]TLC 90 SWB 1KZ-TE
    50mm OEM Lift
    A work in progress & my daily driver[/COLOR]
    http://www.toyota.com/t3Portal/docum...ai/61j1smt.pdf
    This may be of use (may not be for a Prado but should be similar) but if you don't have any history on a vehicle it is best to have a full service and inspection done. I would also be changing all the fluids just to be on the safe side.
    Si & Rae
    [/CENTER]
