Rear light
  • Rear light
    Onto my next project which will be a telescopic rear light. So after some thoughts on size of light. I would like a good light to set up camp and also pack up a boat in the dark obviously using as little power as possible. Any recommendations on brands and place of purchase.
    Leigh
    http://www.4wdsupplies.com.au/lighting/
      Not sure on your location but I got 2 of these http://www.alled.com.au/goods.php?id=2 for $75 for both and I am happy with the output of light that they give out. I found them advertised in 4wd action magazine.
      Ron.
      2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
        I'm running one of these on the back of my 150, puts of a metric shit ton of light and uses approx 2ah. Its shock, dust, water, etc proof
        http://www.ebay.com.au/itm/FLOOD-BEA...-/330675082733
          Yep, I've got the square version of this one also and have it set up on a strong magnetic base which I can stick anywhere on the car and stow it away from grubs when not needed. And if you want brighter than a metric ton of light , there is now a 36w version available for a few bucks more!!!
          Here's my worklight craigm's worklight
          craigm
          Addicted PP Member
            Holy Crap! here's a 48W Led worklight ($90) That equates to 2 metric sh#t tons of light!!!
