Suspension sagging on the right hand side?
  • Suspension sagging on the right hand side?
    Hi all,
    I have a '98 Prado with iron man suspension (fitted by previous owner). We did a trail last weekend and when I returned I noticed that the suspension on the right hand side of the vehicle (back and front) is about an inch lower than the left hand side (very noticable). Ive only had the vehicle for about 2 months and never really noticed this before, so I'm not sure if it occurred after the trail, or whether its something I have just never noticed since I bought the vehicle (pretty sure I would have though). There is definitely a significant different though. I do have air bags in the rear springs (which i thought may be the cause, but then this doesnt explain why the front right is sagging too).
    Regardless of how or when this was caused, is there any way I can adjust the right hand side suspension to get the same height as the left hand side of the vehicle? (there really is about 3 to 4 cm difference between left and right)
    Let the air out of both airbags and see if it levels out. If it does, then there is an issue with the airbag or the pressures are different.
      After a much closer look I think I have found my problem...dont ask me how I missed this! Right hand side sway bar link has pegged. See pics below...(make sure you paste the entire URL into your browser)
      left side...
      www.imagineproperty.co.za/left sway bar link.jpg
      right side...
      www.imagineproperty.co.za/right sway bar link.jpg
