Wat dose EFS mean
  • Wat dose EFS mean
    Having a fit wif a mate wat EFS mean
    Can u please help
    Cheers big dave
    'Wat dose EFS mean'...NFI. 'Fit wif a mate' - WTF?
    [B][SIZE=4]ntp
      Having a fight wif a mate!
        Enhanced (F)our-wheeldrive Suspension?
        http://www.efs4wd.com.au/about.html
        [B][SIZE=4]ntp
          Originally posted by Big dave View Post
          ...wat EFS mean
          Can u please help
          Big Dave. What's the context?
          For Gen Y'ers EFS = Excessive Facebook Syndrome
          Skydivers also use it... Eat, F&$@#}, Skydive
            Thanks mate
              EFS in 4wd world = Enhanced 4WD Suspenion
                http://www.pradopoint.com/showthread...EFS-Suspension
                [B][SIZE=4]ntp
                  ef-s on a canon lens. (not helping)
                  he EF-S lens mount is a derivative of the EF lens mount created for a subset of Canon digital single-lens reflex cameras with APS-C sized image sensors. It was released in 2003. Cameras supporting the EF-S mount are backward-compatible with the EF lens mount and, as such, have a flange focal distance of 44.0 mm. Cameras supporting EF-S, however, have more clearance, allowing lens elements to be closer to the sensor than in the EF mount. Only Canon cameras with the APS-C sized sensor released after 2003 support the EF-S mount.
                  The "S" in EF-S comes from "Small image circle", meaning the lens is designed to provide a small (smaller than a normal EF lens) image circle.[1] The proximity of the rear element to the image sensor greatly enhances the possibilities for wide angle and very wide angle lenses, enabling them to be made smaller, lighter (containing less glass), faster (larger aperture) and less expensive. Most current Canon EF-S lenses are wide angle.
                  EF lens (left) and EF-S lens (right). Note raised ring on EF-S lens.
                  Lenses designed specifically for APS-C sized sensors are often optically designed to provide a narrower light cone to match the sensor. However, not all such lenses require the shorter back focus, and may feature the standard EF mount. Such lenses will give noticeable vignetting if used on a 35mm film or sensor camera.
                    EFS is the encryptable file system Microsoft delivered in Windows 2000 and requires NTFS as its base file system
                      EFS - Electronic Fluorescent Starters are designed to increase lamp operating life up to 2-3 times. The starters are able to sense the ambient temperature and pre-heat cathodes accordingly and eliminates annoying flickering lamps during start-up and operation.
                      [B][SIZE=4]ntp
                        Can u please help
                        Cheers big dave
                        It'd be nice if people could take the time to write properly. Are you drunk?
                        Travelling Panelbeater
                          That is the trouble with texting and all these short message system is no one knows how to write properly any more.
                          They are too busy pulling their undies up high and letting there pants hang low.
                          Not old. Just have some dress sense.
                          SOL.
                            Every Fu*#ing Size.
                            The proper name for an adjustable spanner (shifter).
                            Chriso
                            [COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
                            Previous rig - 02 TD GXL.[/COLOR]
                              SOL.
                              SOL - so is this an acronym too? LOL SOL?
                              [B][SIZE=4]ntp
