Spongy brakes on my 150
  • Spongy brakes on my 150
    I have been having problems with brakes. Felt very spongy also having to press the pedal down a couple of times to bring the pedal up so they would work. Took it into the Toyota dealer that I bought the car off they said it could be the cap off the brake fluid reservoir.....to be more exact the little valve that's there. So they ordered one from Japan. bled the brakes, replace the cap. Fixed. If anyone is having the same thing happening to theirs maybe this post could help.
    Thanks for the info, outback7.
      Your welcome yowie.
        Hi
        Are you able to advise why the cap on the reservoir and the valve inside it impacts the brakes performance? Perhaps it prevents moisture into the system? I also have a spongy brake peddle and have had mechanics bleed them twice to no avail.
          Gidday Lortap, I also had the problem of Toyota bleeding my brakes twice and my brakes still the same. Maybe dirt getting into the valve was the problem, I don't really know. Anyway all is well now.
            The cap has a small valve it it that lets a tiny bit of air into the top of cap , behind the air seal , if that is blocked it is possible to get a cavitation affect inside the cylinder that causes air bubble to form causing the spongy pedal, pretty rare but it does happen
            The other thing that can happen when mechanics do a bleed is pump the brake pedal too fast , this will do the same thing , especially if the fluid isn't from a fresh bottle
              Hi Outback - Thanks for that, I have been having that problem since I bought my GXL 150 new in 2010. Was blaming the missus for being too hard on the brakes when she was sneaking off in the Prado!! Changing to a 2013 GXL on 12 March so will keep my eye on that with the new version.
                Remove the anti squeal shims behind the pads ,with these in it increases the piston travel distance and can give a long pedal.
                Sean
                2011 VX T/D auto pearl white, 3" exhaust and [COLOR="#FF0000"]CHIP IT [/COLOR]module and Auber EGT gauge. Daul battery fitted cig and engel plug in cargo area and charge wires run for the camper. Dual DVD headrests and Extinx GPS/DVD unit. ScangaugeII.
