Hi CraigM, I've just shown your post to our head Air Locker engineer and whilst concurring with Crooza's comments about bearings, he's also offered another potential cause.
"A new diff does shed some of the surface carburisation from gears and thrust surfaces within the first 2500kms, and this is why the first service point is set at such a short interval (as per our service guide pg11). It's called a break-in interval.
For reference, the first service point for a new vehicle (or any petrol motor driven equipment) is also very short for the same reason - so all the fluids can be changed out to flush the particulate from the break-in process.
If the initial service was missed and the diff hasn't been touched in 12 months (usually considered to be 20,000kms per year) then you might have created milky oil by literally grinding up all of the break-in particulate for far too long. Given you haven't found any large particles, indicative of heavy wear or damage, I would suggest driving it for another 5000k's on the fresh oil and then have another look at it for particulate."
He also suggested that over preloading bearings in the rear of a 120 V6 Prado is not a common issue, although shouldn't be discounted as a possible cause.
Hope this helps.
Cheers, Sam.
Hope this helps.
Cheers, Sam.
ARB 4X4 Accessories
