iPhone OBD2
  • iPhone OBD2
    Just wondering if anyone has one of these? If so, can you convert to metric?
    http://www.plxdevices.com/product_info.php?id=GSSTWIFI
    Click on the "iMFD Sensors" tab and you will see all the units available. HTH
      Thx amts. where is that tab?
        Found it thanks. My question still stands is anyone using this solution?
          Can this gadget give diesel fuel injector settings?
          Shifter.
          2007, GXL, D4D Auto, Racor 230 filter with 10 mic (98%) cartridge,
            Shifter, not sure, click on the link.
              When we had the Vic Tech day one of the guys that was there had something like this maybe this one on his phone.
              It worked really good giving all information about the car on his phone . Don't know if it could give you injector settings.
                Does it do anymore than a scangauge?
                  Yes a lot more
                    I'm in early stages of doing this, will report back once I have played around with products I get. Either way there looks to be a few cheaper ways of doing this.
                    OBD2 WiFi (blue tooth will not work with your Iphone)
                    http://www.ebay.com.au/itm/330923219...84.m1497.l2649
                    There are plenty of free and paid apps for apple for on board diagnostics and data display, searching and finding one you like is the next step.
                    Dashcommand (Apple App)
                    http://www.youtube.com/watch?v=3ikwIQfkV98
                    [FONT="Comic Sans MS"][SIZE="2"]09 D4D Prado - Toyota issue White
                    Wrench, Wheel, Wreck, Repeat... [/SIZE][/FONT]
                      Got it working
                      OK. I now have a small, WiFi OBD2 device that is ELM compatible ($20 on eBay) and downloaded Dash Command from the iTunes store. $10.
                      Once setup (took 2 minutes to enter vehicle data, fuel tank size and a few other settings) and remembered to select the device as a Wi-Fi connection every time I get in the car (my iPhone defaults to the WiFi in the house) this app works beautifully.
                      I want it to primarily monitor fuel usage which, alas, is the worst feature of Dash Command at the moment, although they say they are working on it. You have to fill-up a few times for the calibration to be precise and make sure to use the app 100% of the time you are starting the car and driving.
                      My 2008 Diesel Prado (140,000km) is averaging 10.3lt/100km around town and about 8lt/100km on the freeway so sounds about right.
                      There are a couple of settings that are blank;
                      1. Fuel Level
                      2. Range (distance to empty)
                      The Dash Command people tell me I need to have a SAE.DTE PID to get those numerics working. Does anyone know if this model Toyota outputs that particular PID from the computer?
                      Very happy with this low cost solution so far.
