Tyre Size and Low Range
  • Tyre Size and Low Range
    Bit of a debate between me and a guy at work (a friendly debate) Can any one tell me if there would be a big difference when in low range when running say a 70 profile instead of 65 or 75 instead of 70 . Just talking to a bloke at work about it and he reckons the difference would be very noticeable especially when going down steep stuff low range ?? I had bigger profile on both my 90 series and didn't think it made that much difference, not that I noticed anyway. I said I would ask the question !! I know you have to give it a bit more on the black top but I would have only thought this was when you start to get into some serious rubber like 35s etc like some run on patrols/cruisers but then most change diff ratio's to make up the difference and or change over gears in there transfer cases to accommodate the bigger tyres....Cheers Steve
    I'm with you. It makes a difference in 4th & 5th high range but not noticeable geared down.
    Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
      There is no difference at all, there is only about a 4kph difference at an indicated 100kph, meaning, that before the increase, your indicated speed at 100kph would actually really be about 96kph, but now with one size taller profile, and indicated 100kph would be a true 100kph..... what does that mean for low range, absolutely no difference. You will only notice anything if you went up from a 265/65/15 or 16 or 17 up to the next size tyre, being a 285/75/15 or 16 or 17.
        So croozza, going from say a 265/65/17 (say a prado wheel for a good example) to a 265/70/17 there would be noticeable difference in gearing either high range or low range just a difference in speedo reading which I new about that bit as my old prado speedo changed......Im going to print the replys up to show him...............Cheers Steve
          If there is a difference in High range (highway speeds) there will be exactly the same percentage difference in Low range (offroad speeds).
          Going from 70 profile to 75 profile changes gearing by approx. 4% so on the highway (at roughly 100 km/hr) your about 4 km/hr faster for same engine rpm.
          Offroad your Low range will be the same percentage "higher"
          For example; a 90 series Low range is approx. 42.25:1 (1st gear 3.83 x low range 2.566 x diff 4.3) change to 75 profile tyres and the effective ratio is now approx. 40.9:1 ( 4% higher).
          Will you notice the difference ... if you need to now use your brakes to control descents where before you didn't, then yes. Most likely you will not notice the change I would think. As for climbing if your engine has adequate power then that minor ratio "change" I would think would not be noticable.
          As has been said, the greater the tyre diameter change the greater effect.
          Lee
          Leethal
            I went from a 265/65/70 to a 285/70/17 ( 31-33)
            And yes I do alot of hardcore steep rock crawling stuff . I noticed a bit of difference in low range when hill starting on reaaal steap stuff i needed to ride the clutch alot more. It's not bad enough to need a diff ratio change in my opinion , but when I go to 35"s I will be doing diff gears not long after
            2004 Manual Turbo diesel 1KZ-TE , 5" lift , 37x12.5 BF Goodrich KM2
              On a 265/65 to a 70 , there would hardly be any difference
                Lets say your off road in low 1st, you would be doing about 5 to 10 kph, with an increase in tyre profile, at those speeds equates to .2 to .4 kph, you will not notice any change at those speeds.
                  Steve, I went from original Grandcraps to BFG ATs 265x70x17, only noticable (big) difference is better grip.
                  Cheers, Jim.
                  [SIZE=1]Cheers Jim.
                  [/SIZE][COLOR=#0000cd]
                    Difference in radius between a 265/65/17 and a 265/70/17 is about 3.5%. That means for a given engine speed you will be going 3.5% faster, but you will require 3.5% more torque. Unless you were measuring it I doubt you'd notice the difference.
                      The actual difference depends on the tyre brand, type and construction. When I recently changed from a 265/65/17 highway tyre (775mm OD) to a LT265/70/17 Mickey Thompson MTZ mud terrain (810mm OD) the size difference is 4.3%, therefore I needed to adjust the speedo corrector by exactly 4.3% to get the speedo to read accurately.
                      I haven't noticed any loss of performance from the V6 on the road and in low range I suspect the difference would be even less. I'll put the theory to the test on the weekend
                        Difference in low range was minimal
                          31's to 32's in low range would be a very small change.
                          However when changing from 32's to 33's, I noticed a huge difference on road.
