Just wondering I'm putting in a 12 pin flat plug for caravan, just want to make sure I get two things write. Pin 8 orange says for battery charger/ electric winch, pin 9 pink is for auxiliaries etc/ battery feed. I'm running a permanent wire from battery to plug to run fridge in van while on the move and is also for led lighting in van. I'm presuming I use pin 9 pink ?? I'm also presuming pin 8 is if you are running a wire from say a dual battery system for charging any batteries that may be in the van which there is. So again I'm going to put the duel charger under the bonnet and run the wire from the system to pin 8 orange ??? Also what is the maximum size wire I can run which will fit into the wire inlets for these two purposes ?? Cheers Steve [IMG]
[/IMG]
[/IMG]
