Just before Xmas I bought a cheap 2nd hand tyre compressor from Cash Converters... $25.00 with a warranty and it's supposed to pump out 70lt's per min :shock:
I've used it once and it works fine... gets the ST's back up to pressure a lot faster than the Bushranger PowerAir did.
The reason it was so cheap is the leads only just reach the front tyres from the battery (so the back are out of the question :roll and you can only run it for 10-15 mins under pressure.
Off the label on the side...
Voltage: DC12V
Amperage: 23A
My questions are...
1. How do I determine the wire thickness I need for a lead about 6mts long?
And 2.
Can I replace the usual battery terminal clips (aligator type) with a cigarette plug conector to utilise the acc point in the back of the Prado?
Voltage: DC12V
Amperage: 23A
My questions are...
And 2.
