New range of OEM switches
  • New range of OEM switches
    Hey guys, earlier today I emailed the guys over at Newpro-Tech regarding some OEM switches for one of my customers BT-50. They couldn't help me out, but did tell me they have a new range of switches coming out in a couple of days for Toyotas, thats all I know and this is the only picture they sent me.
    www.Newpro-Tech.com.au
    RanJ - Not affiliated with Newpro... got my own company thanks very much!
    I just fitted a pile of Narva illuminated rocker switches. Took a dremel to the Toyota plastic and cut the back end out of where the factory blanks go.
      Narva switches fit with minimal filing. The same switch pops straight into the switch blank in a BT50. They don't look factory but they are a neat fit.
      2011 White GXL Diesel, ARB Sahara bar, Lightforce Genesis, ARB under bonnet compressor, Dual Batteries, GME TX3540
        Yep, trying for the factory appearance in the BT50
          [ATTACH=CONFIG]13575[/ATTACH]
          Yep - I posted this a few weeks ago (this is how long they have been waiting on their supplier) http://www.pradopoint.com/showthread...807#post437807
          I was told there is also a blank you can put the carling labels on for your own purpose.
            It appears they are available now
              The 150 LED Bar says "Rear Lights" though - I have emailed William to see what the go is.
                Shodown,
                I'd say it's just a miss print, as the next switch down also says rear lights with correct picture though, but will be interesting to hear what they say about it!
                  That reminds me. Need to order a switch for the LED light bar. Hopefully swmbo increases my pocket money!
                    Originally posted by Andrew119 View Post
                    Shodown,
                    Nope - it was an error by the manufacturer. Guys, please pay attention when you order.
                    Kevin
                    Hi
                    Sadly yes the dipsticks got it wrong. It’s beyond me how they did that when they sent me a sample picture of the NPT-LS-15LL. We will have the same LED light design as on the NPT-LS-30LL. Just waiting on a time frame for how long it’s going to take. It should not be that long this time as the mould is now made.
                      I've asked what colour the LED backlight is and whether there is a dash light and on light.
                      Edit - and here's the answer
                      The LED colour is Toyota light green. I just had my auto electrician fit the LED light switches in my Hilux. He has them wired up so the text LED light comes on with your park lights and when the switch is pressed in (ON) the LED symbol lights up as well.
                      So if I have my LEDs on the whole switch is lit up. If off only the text LED Light is lit up with dash lights.
                      D4D
                      Addicted PP Member
                        I had presumed that was the case, then your post had me scared as I had already ordered the spottie and blank (for now)...... thanks for confirming.
