Evakool RV 60l Fridge/Freezer
  • Evakool RV 60l Fridge/Freezer
    Have done a little reading on these - I understand they are not a Danfoss compressor and only 2 yr warranty compared to some of the others being 5 - apart from that, does anyone have any feedback on the overall reliability.
    Given the amount and type of use (and the amount of other accessories still to purchase!), this should suit my needs.
    BCF have them on special at $599 at the moment....
    Kevin
    FWIW - they also have a Waeco CDF45 for the same price.....
      $599 is exceptionaly cheap. I have an EvaKool 47 couple of years now no problems at all. it is also one of the better insulated fridges
      Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
        Yeah - I have heard great things about the Evakools with the external mounted compressors (Danfoss), but nothing about the RV series. As this model has only been around a few years - there wouldn't have been too many people who would have given them a true thrashing.....
        It is an awesome deal - cheaper than the the 25 / 35L brothers in the same range!!
          We are getting one for our son but had to take a rain check to get one in a month as they only had 1 display model with a couple of dents and wouldn't come down any lower than the sale price $599 said that was the maximum that they could drop.
          GENERAL INFORMATION
          Compressor : Colku (Based on Danfoss Design and Technology - Made in China)
          Power Source : Built in power supply for 12 / 24 and 240 Volts
          Power usage
          *: Between 1.5 and 2 Amps per hour on average measured over a 24 hour period, motor cycling on/off. Power usage while running 3.75 Amps (RV25 & 35) & 4.58 Amps (RV62 & 82)
          (* Depending on ambient temperature, set temperature, product load etc.)
          Temperature Setting : Between +10oC & -20oC / Up to 50oC below ambient temperature
          Control: Simple to use digital controls for temperature and performance mode
          2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
            I believe that one on sale at BCF is from this range:
            http://www.evakool.com.au/products?sprod=157
            Not from the fibreglass body range. Something worth noting before you part with your hard earned.
              I was looking at the Rv 60 couldn't find anything bad about them.
              $600 is a ripper price for a 60.
              I don't think evakool would put their name to it if it was nO good.
              My contact at rays & bcf says the only fridges that don't come back are ENGELS.
              The others are all good but 1 is the best IMO. Legendary reliability.
                Yep,
                This one caught my eye reading the catalog the other day. As im in the market for a fridge for the work car i think this might just be it considering the asking price of the 40l Engel and Waeco's.
