How far can I push it <0kms cruising range
  • How far can I push it <0kms cruising range
    Guys,
    Diesel, auto and I'm at about 10kms cruising range and the nearest servo is about 50kms away. How far have you pushed your luck before it coughed? I know it's not a good idea as the fuel adds cooling and lube to the pump etc but it might be touch and go here...
    Chris
    [SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
    When mine gets to 0. I reset odometer and have gone 130kms hwy until it surged. (v6 petrol)
    Had less than 2 litres in tank when I filled it.
      I put about 125 litres in mine yesterday with 15 km left till empty, so technically I had 25 litres left... Let us know how you go.
      150 with stuff bolted on!
        Diesel 150 auto and went another 92 a@s clenching km's from zero, I think my wide does it to me to keep me on my toes. I can get in either our prado or rav4 after she has driven it and you can bet its almost empty...
        Daniel
          Found a servo just down the road. With 4kms to go I managed 138lts inc the neck.
            Did over 85km on empty with the warning light on. But still had 11 litres left in the tank when I filled up.
              Wanted to test the low fuel warning light for our upcoming cape trip..
              Had the low fuel light come on, I then drove 42 kms until the needle was reading dead on empty.
              Then the scan gauge reported i had another 101kms left to empty (which is usually very accurate for me)
              Refilling backed this up.
              [B]Robert
                Good results all round, nice to know there is a substantial buffer, still not keen to push it that far though!
                  If I drive my 150 diesel till it says 0km range I can get 140L in the tank so thats 10L to spare or about 100km of city/freeway driving. Be interesting to see what the scan gauge has to say when I get around to plugging it in.
                    last year doing Wolf Creek to Old Halls Creek via station tracks, did the last 110 Km towing a 1500kG Camper with the light on. On filling up at Halls Creek put 140 Litres in, technically 10 to spare It really is a guessing game.
                    Blue Storm 150 D4D GXL, Toyota Tow Bar, Cheepo floor mats, Tough Dog Springs & Shocks, Colour Coded TJM T13 steel bar, KingOne winch with rope, GME 3440 80 channel uhf. Not allowed to make hole for snorkel - yet..
                      Is anyone keen to go for a drive with a spare jerry can of fuel just to see exactly how far it will go until empty
                      VXWesty
                      [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
                      [/SIZE]
                        I got down to 10km to go on the range meter, and the following day had the fuel filter light illuminate. So I'm not advocating going that low again.
                          I wouldn't be keen on doing that either, when you run the tank this low you are more than likely to start sucking up the dregs in your tank, clogging your fuel filter. Just my 2 cents worth.
                            The fuel is constantly being pumped around the system so it's incorrect to say that the last bit of fuel (dregs) in your tank has been lying there going off. Tank to pump to rail to tank to tank and so on and so on. And passing through 2 or 3 filters continuously too.
                              The only time I put 150 litres in was after pulling the tanks out and cleaning them .
                              Cheers Ross
