Rattle at low revs
  • Rattle at low revs
    When accelerating at low revs I can hear a rattle in the engine, I'm not sure if this is just normal, or a problem. Does anyone else hear this ?
    Big Marty
    2006 V6 GXL
    Sorry I have a 150 d4d now, which makes this noise
    Big Marty
    2006 V6 GXL
      Marty, more info please. How old is the 150, how many km, noisier on start up, better when the engine is warm, any white smoke when if first fires?
        I find my 2012 D4D Kakadu rattles more at idle and lower rpm's using Caltex but doesn't using Shell. Don't know why.
        A Happy Camper
        Carey
        Nov2012 Kakadu D4D auto,Toyota bar, IPF900xsHID, ARB/Redarc SBi12 Dual battery, diode,UHF3540, Provent style oil catcher.
          I have found that hiluxs at work that belong the a certain company that only uses caltex rattle and just generally lack a little power and smoothness. I have also found these to block fuel filters quicker than any others. Have found bp to be the best in out area. In saying that if you are labouring your engine too much it will always rattle/ping and not run smooth
          [LEFT]Silver 150 Facelift
            Could be the clutch if its a manual? I've picked up on a similar noise on my 120 today and research is leading me to the clutch area as the culprit.
