Guage options
  • Guage options
    Hi all,
    I am thinking about putting some gauges in my 150 series - boost pressure, oil temp and pressure, water temp, trans temp, exhaust temp. Does anyone know of any digital kits that will show all those gauges in one unit or what are my options.
    Thanks Ben
    I've got a Defi VSD-X that I know if I buy the optional control unit can show the information you need. Not too sure on compatibility with a Prado.
    The other setup I've got is 6 45mm Omori gauges, however I've got volts rather than trans temp. Each set of three fit in a single DIN holder, so double DIN altogether and will be going in the glove box. Obviously more cumbersome but compatibility wise are much easier to set up (for an electrical amateur like myself).
    Then there's a Scangauge that does what you want except oil press and temp I believe, however I could be corrected there.
    Most people on here seem to go with the Scan as it's dead simple to install and gives quite a lot of info.
