12 volt warmer
  • 12 volt warmer
    just wondering wether if anyone has installed a 12 volt warmer .
    I was having a look at the travel buddy warmer - thinking of heating up pies etc
    I have 1 of these http://www.dicksmith.com.au/travel-a...ove-dsau-m4515
    They do a great job of heating but the pie does not crisp up.it is a little soft on the pastry edges.
    But if you have pre cooked food that needs reheating before your lunch stop they are great.
      Travel buddy, warm pies for lunch in the High Country, magnificent
        hey graz , how long would it take to cook a defrosted up a pie?
        I may just have to grab one from dicks - there only $19.95.
        thanks for the info
          D4D- I see you plug your warmer straight into the cig / socket in there rear of your prado. have you had any fuses blow or any problems ?
          thks
            No problems, I did test the current draw before I fitted it and found it to be pretty much what they advertise which was well within spec for the factory socket.
              thanks for the info
              I have one of these, I have put steak and onions in foil also some mushrooms in foil ,a couple of spuds in foil and a small tin of peas (unopened) in the cooker several times now . Takes about 3--4 hours while you drive ,the smell drives you crazy and dinner is cooked when you stop , I cook/warm up pies under the bonnet while you drive ,they get crisp and hot.
                thanks for the info
                We put them in an hour before lunch and they were pretty hot.But they do get a bit soggy.
                Not real wet soggy just not crisp sort of a steamed look.
                We did roll them in alfoil so that would of steamed them up as well.
                For $20 that are great
                Graz
                  That's the beauty of the travel buddy, designed for purpose and pies come out crispy. I usually put a pack and a half of frozen party pies in, 2 hours later hot crispy pies
                    im liking the sound of all this.
                    i was thinking of mounting this warmer on a rack/ shelf.i think the was some sort of rack you could buy that mounts between the two grab rails in the rear of the car , but I cant find any links to it.
                      I've got one of the Dick Smith specials as well. I broke it in up in the High country a few weeks ago, there were a few envious looks as I tucked into my pie for morning tea!
                      I found it took about 45-50 minutes to cook a defrosted pie. As the heating element is on the bottom, I needed to flip the pie over about half way through. I had mine on the passenger seat, plugged into the main 12V socket on the dash, with my iPad plugged into the secondary 12V socket. The pie warmer has a 15 amp fuse from memory, and when it was on, the iPad stopped charging.
                        Hi All,
                        I also have a Travel Buddy 12v Oven in my Prado.
                        It takes approx 2.5 hours to heat, a defrosted pie.
                        I use Mrs Macs Pies which are larger than most pies and heat in the plastic wrapping.
                        During the last 20 mins, I open the plastic wrapper and remove pie and then place back into oven.
                        During this time, I also turn upside down so the pie is crispy Top and Bottom
                        Stuart
                        Stuart Trevena
                        [COLOR="#FF0000"][B]2008 Prado GXL D4D 3.0L T/D 5 Speed Auto Colour: Dune with loads of Extras[/B][/COLOR][COLOR="#0000CD"] [B]and 2015 Tvan MK4 Murranji Offroad Camper[/B][/COLOR]
                          Originally posted by PradoGXL08 View Post
                          Hi All,
                          Stuart
                          You, the truck or the pie?
                            super cheap 12volt warmer
                            just got one of these warmers from supercheap - seem to work ok.( photos courtesy of another site)
