Two aerials
  • Two aerials
    I've seen a few vehicles that have what looks like two UHF aerials mounted on the bull bar.
    http://www.hemamaps.com.au/en/Explor...0020E0374.ashx
    (I have no idea who the bloke is!)
    I'm under the broad assumption that one is UHF and the other for telecom (mobile, etc.).
    Is that the case?
    I have two one uhf one for the phone.
    [b]Rob[/b]
      Ahh...OK...
      Just was reading about running two UHF aerials and they need to be x distance apart, etc....
        I have 2 UHF aerials, but I have 2 UHF's which is probably unusual. I suspect most 2 aerial setups are UHF and phone though.
          You can also buy am/fm aerials to mount to your bullbar. Increase your reception in remote areas. Could account for some 2 aerial set ups you see as well. Since I changed head units my reception is crap so I'm investing in one of these shortly
          http://http://www.zcg.com.au/mobile-am-fm-radio-antennas-sg1100.htm
          People also run hf and vhf radios in there 4wds which could account for a few more.
          The road less travelled is definitely the best road to be on
            Most HF aerials have a much larger base (not all) like mine.
            So they are usually easy to spot.
            One member here has 6 radios in his Prado, so aerials everywhere on that rig
              6 radios, that's awesome, and here I was thinking I was strange for wantin 2 put a vhf in as well. At least with all those aerials he'll always have a spare fishin rod.
                6 radios if your interested http://www.pradopoint.com/showthread...light=Shoehorn
                  Much call for HF in the big island?
                    HF certainly has its place, especially when remote. A UHF is limited pretty much to line of sight where as a HF you can make contact over thousands of kilometers. HF has a network backing it up as well, volunteers all over the country at base stations helping out people with all sorts of things.
                    It's also a useful source of info just listening of an evening and also can be quite entertaining from time to time.
                      Wow, HF is a bit out of the budget....
                        Yea I run two on the left, the wider one is UHF, the skinny one is am/fm
                          Yep I have two as well, both on the left. One is for the UHF and the other for the mobile. My old rig had a third one as well for the FM radio but even with the external aerial it didn't get reception so I haven't bothered with that one on the prado.
                          Some of the travellers we see coming through here have cars that look like echidnas they have that many antennas, I have no idea what they would all be for!
