Tow rating
  • Tow rating
    Can anyone out there give some advise on towing. I am currently looking at a van with a Tare weight of around 1925kg and allowing for say about 475kg of gear ect. Will this be legal to tow with my 150 being a 2012 model.
    Yes as long as the towball weight is 250kg or less. So you'll need to balance the payload carefully.
      Cheers sounds good
        There was a bit of a discussion a while ago here: http://www.pradopoint.com/showthread...ghlight=2500kg
        2500kg towing with 250kg towball weight is the rating for the vehicle. Overseas models have a rating of 3000kg, and there is a lot of discussion (and conspiracy theories) in that link as to why the Australian model is rated lower. I think you recognise from your comment about weight of gear that the actual situation is more complicated than just the weight of the van - it does depend on how heavily loaded the car is too!
        Apparently, GX and GXL models can be upgraded to 3000kg (see here: http://info.kimberleykruiser.com/pra...-road-caravan/). I'm guessing that also applies to your Altitude because the mechanics should be the same (whereas VX and Kakadu models are different).
        Prado_The_2nd now on my Third Prado (and 2 Landcruisers before that!)
        2012 Altitude, Petrol
        ARB Deluxe Bar, Towbar, Driving Lights and bits and pieces of other tech.
          Thank you for your help with that I'll be checking out those links tonight
