RZJ95R clutch
  • RZJ95R clutch
    I am wondering if anyone can tell me if there is a clutch kit available that is going to be lighter than the one I have.
    Cheers All
    hi langy I fitted a Nissan patrol clutch booster to my 150, made the clutch supper light do a search of clutch booster and you will see pics. as a clutch wears they do become heavier (changes the leveraged point of diaphragm) so a new clutch of same strength will feel lighter.
      Thanks Kestrel.
      Can you tell me exactly which booster you got so I can get hold of one and fit it.
      Cheers mate
        I think diesel patrols from 92 through to current have a booster my old mans 93 GQ patrol booster looks the same as the one I got of a GU. make sure you have clearance to brake booster as 150 models do not have brake vacuum booster. should be able to work something out even if you have to mount further from fire wall with longer pushrod. good luck troy
