Tyre Tread Widths
  • Tyre Tread Widths
    Over the years, I've learnt that not all tyres are created equal. Despite the numbers written on the sidewall being the same, the values of the different parameters vary from pattern to pattern. For example, tyre diameters and tread width don't really have a correlation to the sidewall markings.
    So for this thread, I'm making a list of tyre tread widths. This is a measurement of the tread part of the tyre that contacts the ground, as opposed to the overall width of the tyre.
    So post below what you've got and I'll try to maintain the list.
    Download the spreadsheet and have a play
    https://app.box.com/s/iwlpegjm8dytoxmv4hz77otqpyoh7pv5
    16"
    245/75R16
    190mm Maxxis Bighorn
    210mm Pirelli Scorpion ATR
    265/75R16
    220mm BFG AT KO
    285/75R16
    220mm Maxxis 751
    230mm BFG MT KM2
    255/85R16
    185mm BFG MT KM2
    210mm Maxxis Bighorn MT
    17"
    245/70R17
    195mm Dunlop AT20
    197mm Yokohama Geolandar AT-S G012
    265/65R17
    210mm Dunlop AT20
    220mm Bridgestone D697
    225mm Toyo A/T II
    230mm Coopers AT3
    275/65R17
    225mm BFG AT KO
    245mm Pirelli Scorpion ATR
    265/70R17
    195mm Dunlop AT22
    210mm Hankook Dynapro ATM
    215mm Goodyear Wrangler MT/R
    215mm Pro Comp Xtreme MT2
    215mm Toyo A/T II
    220mm BFG AT KO
    225mm Dick Cepek Fun Country
    230mm Cooper ST-Maxx
    18"
    265/60R18
    265/65R18
    The rest
    Continental 5P 285/35 20 - 295mm
    Vee 26x4 - 95mm
    Big Fat Larry 26x4.7 - 120mm
    amts
    Ninja Poster.
    Dick Cepek Fun Country 265/70R17 - 225mm
      Cooper ST-MAx 265/70/17 - 230mm
      Greg - 08 D4D Prado,
        BFG AT 275/65 17 - 225mm
        Pirelli Scorpion ATR 275/65 17 - 245mm
        Pirelli Scorpion ATR 245/75 16 - 210mm
        Maxis Bighorn 245/75 16 - 190mm
        BFG MT KM2 285/75 16 - 230mm
        Maxis 751 285/75 16 - 220mm
        Vee 26x4 - 95mm
        mjrandom
        Out of control poster!
          Nice thread mr.
          You are onto it, most tyre places I speak to dont realise the "section width" is not the " tread width".
          You can gather the data, http://www.tirerack.com/content/tire.../homepage.html
          On tire rack website you can select size & makes/models & compare including all their specs.
            Pro Comp Xtreme MT2 265/70/17. 215mm
              BFG AT KO 265/70/17 = 220mm
              BFG AT KO 265/75/16 = 220mm
                Coopers AT3 265/65 17 230mm
                  255/85R16
                  185mm BFG MT KM2
                  glen_ep
                  Addicted PP Member
                    Hankook Dynapro ATM 265/70/17 210mm
                      A couple to add
                      265/70/17
                      Toyo Open Country AT II 215mm
                      245/70/17
                      Yokohama Geolandar A/T-s 197mm
                      Dunlop AT20 Grand Trek 195mm
                      Interesting that the toyo at2s are 10mm wider in the 65 profile than the 70
                        Sorry the 255 measurements were a little bit out - updated on my previous post.
                        Interesting to see some of the 285 and 265's are very close in width to the 255's!
                          I was surprised how (relatively) narrow the 285s were.
                            The tyre numbers refer to section width as mentioned above not tread width , it is the width measued at a specific section of the tyre on a specific rim (dont ask me what sort of rim)
                              Thank you all for the info. I have also created an excel spreadsheet with funky colours and bars that vary in length depending on the width recorded. Feel free to play with it. It's in the first post.
                              A pattern seems to be emerging in that MT tyres are narrower than AT tyres. In terms of offroad performance, given the same overall diameter, a narrower tyre will give you better offroad traction when driving over uneven ground (think tank tracks). This is because a narrower tyre will have a longer footprint. I don't know how much better it will be but it's something to mull over next time you're at the camp fire and discussing/comparing the day's run with your fellow companions.
