12V Help from resident leccy pro's?
1999 Toyota Landcruiser Prado RV 4cyl 2.7L Manual, Lifted 2-3" on Dobinson Springs & Shocks, Cooper STT Max Mud-Terrains in 235/85R16 all-round 32", Custom no Bullbar winch mount with Runva 11XP Winch, Black Sliders, 10000 Lumen, LED LightbarTags: None
It's not the way I would do it.
Your fuse is a good size for 8 AWG. That's fine.
The problem is if you have a device fault or short in the device or cable, you can put up to 30 amps across a cigarette socket and device designed for less than 10 amps. That is not good.
The reason you put the fused block in the back is to "branch" off your larger cable to smaller cables and lower power circuits. Your cigarette light is another branch.
I would rather run a separate wire from your fused block in the back. I would run a length of 4mm TYCAB twin core (rated to 22 amp) and run it off a 15 amp fuse for that circuit. It also means if you have a problem on that circuit you can isolate and diagnose the fault a lot easier, rather than knocking out your entire system.
Cheers Chilli.
A fuse is meant to protect the wire and should be as close as possible to the power source.
So the fuse should ideally be less or equal to the "ampacity" of the wire. Here is a chart
http://www.cerrowire.com/ampacity-charts
Assuming that your 8G in your diagram is 8awg, then use the 60deg column to determine ampacity, which in your case = 40A.
Technically, if you are using 8awg all the way, then a single 40A fuse right near the battery will suffice. However, this is not the case as you most likely may not have 8awg wire connecting the cig sockets and anderson plugs to your devices. So you would want to fuse each junction according to the maximum ampacity of the wiring. eg. a typical cig lighter cable is rated to 10 or 15A. If there is no fuse within the plug, then your cabling needs to have a 10/15A fuse.
thanks all, will separate the ciggy points with a different fuse direct from battery. ta.
SAMUEL[I]Maroochydore, Sunshine Coast, Queensland[/I]
