Installing a winch on primary battery
  • Installing a winch on primary battery
    Hey Guys,
    The family and I are now starting to venture out to beginners 4wd trails. I currently have a set of Treds and recovery gear and just for insurance I was planning on getting a winch which I highly doubt I would ever use.
    Can anyone see why I should not hook it up to my factory cranking battery? Once the battery needs replacing I will get a better battery. Also I don't plan to get a secondary battery as yet.
    evltoy
    Prado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
    Most of us with winches have it hooked direct to the primary (starting) battery. The engine should be running during the winching process. This ensures plenty of amps to drive the winch motor. I have a dual bettery set-up where I can link the batteries but have never needed both to run the winch.
      I was talking to a bloke at battery world a couple of weeks ago about a dual battery setup.
      He told me to keep my winch on the starter battery otherwise it will drain the second in no time.
      Also that it isn't good for the kind of battery I want. (Deep Cycle)
        Yeah I have my winch on the crank battery, my second battery is in the cargo area, so crank was the only option. Pretty common practice.
          I'm doing something a little different and running the winch of the aux (optima yellow) not the (factory) cranker, but wiring up a changeover relay so that both batts are linked during winching.
          Micheal.
            I have done the exact same as you, 120D4D. So far it has worked very well.
            As others have said I always run the engine when winching.
            Greg - 08 D4D Prado,
              Have you gone down the manual switch path, or auto swtiching via a +ve feed in winch control box mate?
              Micheal.
                Well it looks like what I plan to do is the norm.
                Thank you to all for responding... it has made my planning decision an easy one.
                Now to get myself a winch
                  I just have a manual isolator under the bonnet and use the standard +ve wired switch to the control box or remote as desired. (If that's what you are asking)
