how do you like your brake pedal
  • how do you like your brake pedal
    Hi all
    So my question is do you like a soft pedal with a bit of travel or harder with less or no travel.
    Normally I do prefer a hard pedal in a car but my Prado has quite a soft pedal. Should it be softer for off road work or is it personal preference.
    Shane
    Hi Shane
    A question for you
    When was the last time the brake fluid got changed ?
    this makes a difference if it hasn't been done for quite a while .
    hope this helps
    Tony
      About two months ago when I brought it.
      I'm only asking as this is my first 4wd and I'm use to havin hard pedals in a road car and the Prado is quite soft and thought maybe it is ment to be like that for off road
        Cause there made to keep soccer mums happy
        Arb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
          I like my brake pedal like my women. firm, and responsive to touch....
            Hi all
            Shane
            theres some thing wrong with your brakes find whats wrong and fix it. The pedal should be as hard and solid as any commodore.
            I got myself some Big Horn Maxxis and was telling my landrover lover mate he said what size did you get I told him 265/75/16 he said I didn't know they came that small.
              Ours is soft too but I also drive a Jazz so just put it down to different cars.
                Somewhere between Firm and squishy. I dont want to feather the brake and stop dead. I also dont want to have to search for the point where my brakes start working.
                Spilsy
                  Mine is quite solid and stiff. While all the fluid is changed on a regular basis, I have changed all 5 hoses for braided.
                    I like my brake pedal to be connected to the push-rod that goes through the booster and on into the master cylinder.
                    Some years ago, whilst driving my modified 66 XP Falcon sedan-delivery, with 289 V8, C4 and 9 inch conversion, the pedal separated from the pin securing it from the push rod. Failed to negotiate a left hand bend at about 80km/hr, mounted the kerb narrowly missing another motorist, hit a sand embankment and launched into the air coming down hard on the nose. Everything forward of the firewall was bent.
                    After getting the chassis rails straightened I sourced an old ute and cut the front end out of it and glued this to the van. She came back together smoother, blacker and tougher with the sides filled in and coffin rack removed and new rims. Sweet. Should have kept the old shagging wagon.
