Bushranger X-Jack
  • Bushranger X-Jack
    I cannot get my new Bushranger X-Jack to stay on the exhaust pipe of my new Prado.
    No matter how hard I push it on, it blows off as if it is blocked.
    The outlet hose (straight out of the bag) appears to have a fitting on it which totally blocks the hose.
    This may clear when the two hoses are clipped together but it does not look like it will.
    I later found buried deep inside the bag, an instruction saying that "the exhaust pipe of some Landcruisers are finished at an acute angle and an ancillary extension pipe is required so the exhaust jack will fit snuggly".
    This sounds like my Prado exhaust pipe (2016 Kakadu Petrol) but can anyone advise if they have had this problem and if the ancillary pipe will fix the problem.
    You would think that I would have been advised about this by the 4x4 shop where I bought the jack as they knew I had a new Prado!!!!
    Thank goodness I discovered this problem before I needed the jack when bogged!!!!!
    Please advise.
    Thanks.
    David
    looks like i need to check mine as well
    bit like my pair off maxtraks
    something to carry that most likely not get used with the prado
      Yeah the guy in the 4x4 shop asked me if I would be using this jack this weekend but in hindsight, the answer is obviously NO as the &&^^$##%^&(_*&_(*^*& thing does not work! I should have bought the 3 times cheaper one from Supercheap Autos but then that may not have worked as well! OH the pains of being a consumer these days. Rule of thumb. Assume nothing will work until you trial it!
        Fill from compressor is better, clean and not so hot air.
          how long does it take with the compressor? I am thinking of buying one of these jacks, but I was afraid the compressor would overheat trying to inflate it.
