Are Wireless Tyre Deflators Possible?
  • Are Wireless Tyre Deflators Possible?
    Hi Guys, I've been thinking about this for a while and I'm wondering if there's some mechanically or electrically minded people on here who can explain why it won't work. It seems to me that it shouldn't be difficult to upgrade the top of the range tyre pressure monitoring systems to include a tyre deflation function, programmable from the display.
    There already exist some pretty fancy wireless systems that send the pressure readouts wirelessly back to the in-cabin display. Some seem to be set up inside the tyre before it's fitted and others are screw on replacements for a tyre cap. Presumably they keep battery charge somehow using the energy of the wheel's rotation to recharge their batteries.
    What I'm picturing is either a screw on one, or maybe a complete replacement for the valve stem, with a little actuator in it that can depress the valve stem and start letting out the air. You're driving along at 35PSI, you're heading for the sand, you dial in that you'd like to drop to 18PSI on the display and the actuators depress the stem and start letting air out. They'd have to be smart enough to stop it every 10 seconds or so to check the pressure and then keep going or something but that doesn't seem too difficult. Sure it'd be slow, but not much slower than a set of Staun's and if you could kick it off when you're still 2k's from the cutting, you'd get good at timing it just right.
    I get that it'd never work for re-inflation but surely a little actuator wouldn't be that much harder to add to the fancy TPMS's to allow for deflation on the move.
    I'm assuming there's some simple principle somewhere that I'm missing that means it won't work because no-one seems to have invented them yet. Maybe there isn't and I've just given someone the start of a multi-million dollar 4wd accessory empire (if that's the case, I'm hoping whoever gets rich off it will sling me a set of freebies as a thankyou) but I suspect it's more likely there's some good reason why it hasn't been done yet. Let me know your thoughts.
    Tiny
    would be a great idea, some of the commercial ones out there are fed by hoses on the outside of the hub and would be vulnerable off road (rip hoses from hubs, the hummers have a great system but use a portal hub i believe....
    http://auto.howstuffworks.com/self-inflating-tire2.htm
    2010 Blue Storm GXL Deisel Auto, HR towbar, uniden UHF, 270/65/17 BFG A/T, Delux ARB bullbar (FITTED), IPF Xtreme Spotties, Safari Snorkel (to come) Sungrabba mats (awesome)
      It has been around for a while https://en.wikipedia.org/wiki/Centra...flation_system
      From memory the Hummer had such a system for deflation and inflation however it was not wireless.
      S.
      155 SX with dual battery and Polyairs in the rear springs..
        A CTIS is different to Tiny's question. He's not wanting to inflate them again.
        It's probably possible but the battery life would be the biggest issue I suspect. Not sure how much power you'd need to drive the actuator though. And you're still going to have to get out to inflate them again.
        I suspect the cost or complexity of such a system would far outweigh any benefits.
          Anything is possible. Just the cost of developing it for the limited market. It probably would not need to use a lot of battery power as the pressure difference from inside the tyre V atmospheric pressure could be used as an energy system to drive it. It would required either extreme miniaturisation to fit inside an inflation stem or else some larger complex fitted at the time the tyre goes on the rim, yes quite doable but likely very expensive. As much as I like the idea of pressure monitoring the current systems are at a price point that I have yet to see value for money that being the case there would be even fewer people ready to fork out for and even more complex and expensive system.
          2009 120 GXL D4D, TJM Bull Bar, Winch, Safari Snorkel, ARB Lift, ARB Lockers, Black Widow Drawers
