CB Aerial cable path from bullbar mount
  • CB Aerial cable path from bullbar mount
    Hi all,
    Am looking at installing a CB in my 99 Grande.
    The bullbar has a welded mount at the top for the aerial.
    Just wanted some ideas of where to route the cable back to the unit inside.
    Is it best to cable tie down the cable to the bullbar base then through the grill, around the engine bay and through the firewall, or is there a better path?
    Not into river crossings etc, so no expected water egress to cabling.
    Picture is of a similar bullbar aerial mount i have.
    1999 Prado VX Grande White on Silver 3.4Ltr Auto
    Down the bar on the bullbar, then under the grill, not through it, an d then up the passenger side, probably through an opening beside the headlight, then beside the battery and through a grommet on the passenger side and in behind the glove box.
    2015 GX Prado 3L Auto, in the process of being fitted out.
      Mine goes into the bullbar at the mount and then through the inside of the side hoop and then the engine bay as per MYT150
        Thanks guys...
