Long story as short as possible,
I went to change the spark plugs and the leads tonight to find one of the spark plug wells had a fair bit of oil in it. The plugs and leads were well overdue but the main catalyst was that it has been backfiring. From a quick search it looks like the most common culprut is a gasket/o'rings but can be far more serious.
First question is how do I go further about identifying what the actual cause might be, is there anything I can do find out without stripping it down? Second is should I keep this totally off the road until its fixed or would it be okay to drive for another couple of day's whilst I get the repair organised. Thirdly anybody got any ideas as to the likely cost of repairs?
Some other probably pertinent information.
*Car was backfiring at least in part to a couple of different air leaks making it run lean, although the old plugs and leads probably weren't helping. Its a bit of a vicious circle backfire leads to an air leak leads to more backfires.
*Car is dual fuel and has done about 200,000km on LPG, I have heard it can be harsh on the valves so I am suspect this may be where my problem lies. I have used flash lube for a large portion of that time but the periods between filling up I cant be sure of.
*Car has been noticeably missing (I think its what you would call it, lets out a couple of pop'pop noises as opposed to a loud bang of a backfire) only in the last few days but only occasionally when some times accelerating away from the lights after idling for a bit or accelerating up a hill after coming down a previous one.
*The plug from the well with oil in it looked like it has seen far less wear than the other's makes me think that cylinder hasn't been running for a while but I haven't noticed a rough idle (see next comment) and only a slight loss of power.
*Idle has been rough a few times but this has been due to a backfire sooting up the airflow sensor, I think it has now however beyond cleaning and now needs to be replaced.
*Has backfired on both Gas and Petrol.
Any help appreciated
