2016 Prado Kakadu lift options
  • 2016 Prado Kakadu lift options
    Can someone tell me the best way to lift my Kakadu body to give me some extra clearance. I have the normal Kakadu rear lift but that doesn't do much and although the documentation says that the suspension is "self levelling" I am not sure if that means that when the back end lifts when using the on board rear lift, that the front levels by the same amount. I suspect the answer is no but just curious. So, my questions are:
    1. How much can I expect to be able to lift the body (air lift to adjust the height when required would be nice).
    2. What would be a fair fitted price.
    3. Who are the best manufacturers to investigate.
    Any advice would be appreciated.
    Cheers Kakadu Dave
    Self leveling means that whatever the load, the rear will stay at the same height. The front does not come up.
      Cheers Kakadu Dave
      Check out some Dobinsons coils for the front. Raise it 30-40mm with those.
      Adjust rear sensors a little, 20-30mm
      That's all you need. Simple & reliable.
        Thanks. That makes sense!
