Igntion Problem
  • Igntion Problem
    Dear All,
    i have a problem today with my Prado 2006. Problem is this that i unlock it with remote and after inserting key in ignition switch the ignition rotating free and engine not starting even if i rotate it back to off and remove key the warning lights was on. i tried to lock/unlock with remote but not working then i remove the battery wire.
    any suggestion please.
    Regards,
    My advice is to invest in a high-quality coating if you don't plan on doing a lot of off-roading in the woods and rugged terrain and value maintaining a showroom appearance for your vehicle at all times. It's easy to clean, and after a thorough washing, it returns to pristine condition.
      Thank you for sharing your problem for readers, I am re-reading the information you gave to come up with the most reasonable answer. wordle hint
        If you value preserving a showroom appearance for your car at all times and don't intend to do a lot of off-roading in the woods and rough terrain, my recommendation is to invest in a high-quality coating. It's simple to clean, and after a good washing, it looks brand new.
          Thank you for letting others in on your predicament; I'm now re-reading your post to figure out how to best respond to it.
